[Qgis-user] no python console in QGIS 3 Ubuntu 17.10
Patrick Dunford enzedrailmaps at gmail.com
Tue Apr 17 03:50:15 PDT 2018
If you use the Ubuntugis packages and they break the installation
because of their different upgrade cycle the answer to that is to use
apt pinning to block the automatic upgrade in the package management system.
The point made with Ubuntugis is the same as if you were getting the
packages from Ubuntu itself. The update cycle for Ubuntugis or Ubuntu is
not controlled by the Qgis project.
You are not compelled to use the Ubuntugis for the LTS versions of
Ubuntu but then you will get an older version of Qgis installed on your
computer. So there is a very straightforward set of choices that can be
made.
On 17/04/18 06:11, Micha Silver wrote:
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180417/95cab9fa/attachment.html>
