[Qgis-user] QGIS3: Running processing algorithms in a plugin using QgsProcessingAlgRunnerTask
Havard Tveite havard.tveite at nmbu.no
Mon Apr 23 08:12:50 PDT 2018
I would like to use a processing algorithm in a plugin,
and run it as a QgsTask to avoid user interface "freeze".
I have tested with QGIS 3 (3.0.2) using the "native.buffer"
algorithm and a line vector layer:
  context = QgsProcessingContext()
  alg=QgsApplication.processingRegistry().algorithmById('native:buffer')
  params={
    'INPUT': inputlayer,
    'DISTANCE': 100.0,
    'OUTPUT':'/home/test.shp'
  task = QgsProcessingAlgRunnerTask(alg,params,context)
  QgsApplication.taskManager().addTask(task)
The algorithm runs fine (the progressbar in the status
area at the bottom of the QGIS interface is counting up
to 100% and the buffer data set is generated and OK),
but QGIS crashes immediately after the algorithm has
completed:
  QGIS died on signal 11Could not attach to process.  If your uid
matches the uid of the target
  process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
  again as the root user.  For more details, see
/etc/sysctl.d/10-ptrace.conf
  ptrace: Operation not permitted.
  No thread selected
  No stack.
  gdb returned 0
  Aborted (core dumped)
It would be great if someone could explain the proper way
of using QgsProcessingAlgRunnerTask, and perhaps provide
an example of how to use it in a plugin.  I have tried to
search the web, but have not found much.
How should the "context" be set?
How should the task and the results be handled?
Håvard
Håvard Tveite
Faculty of Sciences and Technology, NMBU
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 67231548   Web: http://www.nmbu.no
