[Qgis-user] Exporting from Print Composer causes the OpenLayers plugin satellite map to shift position?
Ujaval ujaval at gmail.com
Thu Apr 26 02:43:00 PDT 2018
Hi Leo,
Welcome to the mailing list and to QGIS! Use QuickMapServices plugin
instead of OpenLayers and the problem should go away. See this exchange for
more details
https://gis.stackexchange.com/questions/42044/openlayers-low-resolution-and-or-shifts-in-qgis-print-composer
-Ujaval
On Thu, Apr 26, 2018 at 2:36 PM, leo jhaveri <leo.jhaveri at hotmail.com>
wrote:
> Hi,
> I have a reoccurring problem which is the bottom layer of my map (Google
> Satellite OpenLayer plugin) shifts position between working in the Print
> Composer window and exporting the file. However, the .shp layers (lines and
> points) stay in the correct place relative to each other and the grid
> frame.
> This problem occurs also when using Bing Arial OpenLayer instead of Google
> Satellite. I have tried using both versions 2.8.3 and 2.18.18, and the
> exact same thing happens.
> What can be done to stop the layer from moving during the export? Using
> print screens for presentation limits resolution quality, and there has to
> be a solution to this problem.
> This is my first time using this emailing list and I am very new to QGIS.
> Thanks for your help,
> Leo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180426/a2db6c29/attachment.html>
