[Qgis-user] QGIS 3.2.0 Layer Style issue
Andreas Neumann a.neumann at carto.net
Thu Aug 2 01:25:38 PDT 2018
Hi Richard,
Have you tried setting the "No symbols" renderer in the symbology? Such
features should still be available for labels, but aren't drawn.
Andreas
On 2018-08-01 15:58, Richard McDonnell wrote:
> Afternoon all,
> I have ran into a little issue in styling on QGIS 3.2.1.
> I have a line style ceated for a road network, what I want it to do is display the Lines and Labels between, say, 1:2,000,000 and 1:20,001 and from 1:20000 to 1:500 just the Labels.
> I have used Rule based styling to create a style, with separate overlapping Scale Ranges, which works perfectly for 1:2,000,000 to 1:20,001, but once the Lines (Symbology) disappear, so do the Labels.
> If I reset the Scale range on the Symbology (Have no restrictions, the Labels work as required, all the way to 1:500.
> It seems that even though I have separate scale ranges set for both the symbology and the labels, once the symbols switch off so does the labels.
> Is there a way for me to do what I want without having to duplicating the network layer, so as I have a separate Symbols layer and Label Layer.
> Any help appreciated.
> Regards,
> Richard.
> [1]
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Qgis-user mailing list
Links:
[1] http://www.opw.ie/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180802/523fc981/attachment.html>
