[Qgis-user] Cursor turns to spinning wheel the second I start QGIS
magerlin MAP at ramboll.dk
Sun Dec 2 03:49:51 PST 2018
Thanks, I am aware of that but with something like 100 installed plugins it
is a little hard to decide where to start.
But I did this instead:
I looked up the installation folder for plugins:
C:\Users\xxx\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins
And sorted it by date. By that I found possible problematic plugins based on
when I think the problem started and I simply moved the folders of the
plugins to another place on my harddisk one by one and restarted QGIS every
time.
And I found the problem was in a folder named Nominatim, whick I found out
was the OSM place search plugin.
I have now reported it as a bug on the plugin bug tracker
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
