[Qgis-user] disabling qgis.db
Régis Haubourg regis.haubourg at gmail.com
Mon Dec 10 08:12:10 PST 2018
Hi Benjamin,
I think the guidelines for software generally assumes that user profiles
should be in editable location. I'm not sure we can ensure you in the long
run that you will not face regressions sometimes.
To adress your use case, I used to work with session startup script that
cleared / reset user profiles on session close or session opening. The
assumption was to let user free to change their profile settings but not
for all settings (mandatory plugins for instance, default SRS..)
Cheers
Régis
Le lun. 10 déc. 2018 à 16:19, <Fuenfer-Koenigstein.Benjamin at swm.de> a
écrit :
> Hello,
> I have an issue with creating a central QGIS configuration on a network
> drive. The goal is to have one read-only configuration that all users use.
> Generally works like a charm with starting QGIS 3.2 with --profiles-path
> pointing to a read-only dir. Users get the right settings, they still can
> play around but changes are discarded when quitting QGIS. Only problem is
> qgis.db, seems that QGIS necessarily needs write access to that file,
> otherwise it throws an error at start (but works with no problems
> subsequently). Is there any way to avoid that, e.g. starting qigs ‘silent’
> or setting the path to qgis.db to a local user folder? Seems that qgis.db
> doesn’t contain any crucial configuration, though same bookmarks for all
> users would be nice to have.
> I’m aware of https://issues.qgis.org/issues/13732 and generally
> understand Nathan’s and Nyall’s point of view but still think it would make
> sense to ignore qgis.db for use cases like mine.
> Thanks for your ideas and help!
> Regards
> Benjamin Fünfer-Königstein
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181210/bacfdb4c/attachment.html>
