[Qgis-user] QGIS 3.4.2 still very slow to work in Windows 10
Mike Flannigan mikeflan at att.net
Tue Dec 11 07:11:11 PST 2018
I can report that I do not see the same thing reported
below.  I use QGIS 3.2.0 on Win7 with a pretty good graphics
card and I don't have any problems at all.  I'm thinking it
has perhaps froze up a couple times since the install in late
June 2018, but I don't recall the last time that happened.
I just opened a project with 266,000 point features, and it
takes 18 seconds to open the attribute table, but works
flawlessly.
I am using Intel Zeon CPU E5-1630 v4 @ 3.70GHz - 16GB Ram.
I have never tried QGIS 3.4.1.
Mike
On 12/10/2018 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Hi David,
> everything you've detected happens since the transition to 3.x also on
> windows 7 on PC with i7 4780 and 32GB ram.
> any operation, even the simplest one, such as saving or calculating polygon
> areas in a shapefile causes freeze of QGIS. Not to mention the node tool
> where a forum should be open apart there is a ticket here but only 8 people
> have participated ...
> (http://osgeo-org.1560.x6.nabble.com/Node-Tool-proposing-improvements-td5387054.html).
> Moreover:
> - there is  no currently a native topological verification tool of
> shapefiles (the new validator incorporated in editing is almost impossible
> to run on shapefile with hundreds of polygon in ...)
> It will take years, in my opinion, before the 3.x version can be used
> productively.
> Unfortunately, the gap between users and developers remains gigantic,
> although most of the developers say that users have been asked .. sin until
> 2.18.x everything was wonderful.
> I Hope that somebody from QGIS.org can see our perplexities and adjust as
> far as possible this version which for now remains only a container of good
> ideas
> Regards
> Antonio
