[Qgis-user] how to properly reference longitude values in different datasets
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Thu Dec 20 23:09:18 PST 2018
Did you open your layer as Mesh layer or Raster?
Cheers
Saber
On Fri, 21 Dec 2018 at 05:59, Lee Eddington <lee.w.eddington at gmail.com>
wrote:
> That worked.
> Thanks,
> Lee
> On Dec 20, 2018, at 6:06 AM, Saber Razmjooei <
> saber.razmjooei at lutraconsulting.co.uk> wrote:
> Climate Data Operator (CDO):
> https://code.mpimet.mpg.de/projects/cdo/
> cdo sellonlatbox,-180,180,-90,90 input.grib output.grib
> Regards
> Saber
> On Thu, 20 Dec 2018 at 13:00, Lee Eddington <lee.w.eddington at gmail.com>
> wrote:
>> Can you point me to the external tools?
>> Thanks,
>> Lee
>> On Dec 20, 2018, at 12:46 AM, Saber Razmjooei <
>> This is a known issue and can be fixed with some external tools.
>> I have filed a bug:
>> https://issues.qgis.org/issues/20853
>> And hopefully get around to fix it in 3.6
>> Regards
>> Saber
>> On Thu, 20 Dec 2018 at 01:44, Lee Eddington <lee.w.eddington at gmail.com>
>> wrote:
>>> I’m pretty new to QGIS and am trying to figure out how to modify
>>> longitude values of layers.  I was able to add a raster layer in GRIB2
>>> format (NCEP global meteorological data).  The longitude values range from
>>> 0 to 360 degrees.  I’m able to view and do calculations on the data with no
>>> problem.  I also added shaded relief and coastline data from Natural
>>> Earth.  This data has longitude values from -180 to 180 degrees.  So from
>>> -180 to 0 degrees I only see the Natural Earth data, from 0 to 180 degrees
>>> I see both datasets and from 180 to 360 degrees I only see the GRIB2 data.
>>> I want both datasets to be referenced the same with regards to longitude
>>> (-180 to 180, 0 to 360 or whatever).  It seems like this should be a fairly
>>> easy problem to fix by either adding 180 degrees to longitudes from the
>>> Natural Earth data or subtracting 180 from the GRIB2 longitudes, but I
>>> can’t figure out how to do it.
>>> I’m using QGIS version 3.4.1-Madeira.  The CRS I’m working in is what
>>> QGIS put the GRIB2 data into when I added it:   * Generated CRS
>>> (+proj=longlat +a=6371229 +b=6371229 +no_defs)
>>> Thanks,
>>> Lee
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Saber Razmjooei
>> www.lutraconsulting.co.uk
>> +44 (0)7568 129733
> Saber Razmjooei
> +44 (0)7568 129733
Saber Razmjooei
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181221/855368f4/attachment.html>
