[Qgis-user] exporting QGIS maps to gps for field work
nwastra nwastra at gmail.com
Sun Dec 30 14:48:44 PST 2018
I expect QGIS can save your data as geotiif. This article mentions a method using geotiff and GDAL to convert to jnx
http://whiter.brinkster.net/en/JNX.shtml
N
> On 31 Dec 2018, at 6:57 am, qgis-user at stripfamily.net wrote:
> I think the gpsmap 64 uses both proprietary Garmin image files and jpeg files for maps.  The image files are quite difficult to create, though all the information is out there if you're patient
> Uploading jpeg images is much simpler, and the instructions can be found on the Garmin website here or here
> You can use the Map Composer in QGIS to create a map with annotations and such that can be exported as a jpeg, or you can just export from the map canvas -  Project->Import/Export->Export Map to Image
>> On 29.12.18 13:52, Rutger Emmelkamp wrote:
>> Hello everybody,
>> I’m fairly new to QGIS but I’m loving what I’ve encountered so far.
>> What I wish to do now is adding information layers to scanned geological maps and then export them to my Garmin gpsmaps 64s so I can work with the maps in the field.
>> What would be the way to do this? Is it possible to create jnx files with QGIS or is there another way?
>> I read about the GPSBabel plugin but it does not show in the plugin list.
>> I have QGIS3 3.4.2 Madeira installed on OSX. Don’t know if that matters.
>> Hope someone can help me in the right direction.
>> Thanks!
>> Rutger
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181231/e59125cc/attachment.html>
