[Qgis-user] QGIS Mapserver - Project administration and updates, documentation
Albin Blaschka albin.blaschka at standortsanalyse.net
Fri Jan 5 01:43:01 PST 2018
Am 2018-01-05 um 10:17 schrieb Andreas Neumann:
> Hi,
> I agree with Alessandro. Only keep one instance of the binary around.
> Otherwise you start a mess.
> Also - you should not have the project files in the same directory
> than the qgis_mapserv.fcgi. That is bad practice. QGIS project files
> often contain sensitive data (like database logins or logins to web
> services) and should not be accessible in any URL reachable to the
> public - neither in cgi-bin nor in other html/www paths.
> To support different projects in different directories, use a rewrite
> rule - which also hides the full path (good practice).
> Andreas
Hello!
Good point, yes - but as mentioned in my first mail, this was part of
the documentation until recently... I set up my instance quite some time
ago and did not think about it, as it was until recently just a
proof-of-concept/test work, not really meant to be in production. And
now I stumbled over it, as this changes now.
I will propose changes for the documentation in the next days, also
considering all input now coming in in this thread (Hint to all readers:
Provide input! ;-) )
Thanks, best regards,
Albin
> On 2018-01-05 09:59, Albin Blaschka wrote:
>> Hello Alessandro, hello Richard!
>> Yes, I will in the next days - and thanks Richard for the step by
>> step guide!
>> Albin
>> Am 2018-01-05 um 09:43 schrieb Richard Duivenvoorde:
>>> On 05-01-18 09:35, Alessandro Pasotti wrote:
>>>> On Fri, Jan 5, 2018 at 9:27 AM, Albin Blaschka
>>>> <albin.blaschka at standortsanalyse.net
>>>> <mailto:albin.blaschka at standortsanalyse.net>
>>>> <mailto:albin.blaschka at standortsanalyse.net>>> wrote:
>>>>      Hello all,
>>>>      Following an update on my Linux-Server (Ubuntu), where I have an
>>>>      instance of qgis mapserver running, I stumbled upon a small gotcha -
>>>>      it stopped working.
>>>>      The reason was simple: The binary of qgis_mapserv.fcgi got updated,
>>>>      but when I set up qgis mapserver, I followed the suggestion as
>>>>      described under
>>>> https://docs.qgis.org/2.18/en/docs/user_manual/working_with_ogc/server/getting_started.html#installation
>>>>      <https://docs.qgis.org/2.18/en/docs/user_manual/working_with_ogc/server/getting_started.html#installation>
>>>>      under the heading "Server the project" to put a project into a
>>>>      separate directory with the .qgs file and a *Copy* of qgis_mapserv.fcgi
>>>> I think that spreading copies of the CGI binary on your directory tree
>>>> is bad practice and calls for troubles, a symlink works surely better
>>>> but there are many other ways to serve a particular project depending on
>>>> the URL (any rewrite module for your favourite server would be sufficient ).
>>>> Would you mind making a pull request and fix the documentation?
>>> Yes, please do:
>>> - create a github account if you net have one
>>> - go to latest version of the page:
>>> https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/getting_started.html#installation
>>> - click the 'fix me' link in the footer which brings you to
>>> https://github.com/qgis/QGIS-Documentation/edit/master/source/docs/user_manual/working_with_ogc/server/getting_started.rst
>>> - you will be asked to create a fork, do that, update the docs (just
>>> using Github editor...), and do a pull request
>>> - if all fails, then please create an issue with a pointer to this
>>> discussion: https://github.com/qgis/QGIS-Documentation/issues
>>> For all other people: PLEASE try to help QGIS to get uptodate docs by at
>>> least try to write/update some docs every now and then. I think the plan
>>> above is doable for every tech savvy QGIS user...
>>> And again: if all fails: write an issue, and preferably attach a new
>>> text to it.
>>> Regards,
| Dr.rer.nat. Albin Blaschka
| Etrichstrasse 26, A-5020 Salzburg
| * www.standortsanalyse.net *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180105/c25658d4/attachment.html>
