[Qgis-user] No 3D menu item
Andreas Neumann a.neumann at carto.net
Sat Jan 6 04:11:17 PST 2018
Hi Bernd,
I would recommend upgrading to Ubuntu 17.10 which comes with qt5.9
Andreas
On 06.01.2018 13:07, Bernd Vogelgesang wrote:
> Hi Andreas,
> do you know if there is a recommended way to get qt5.9?
> It seems not be available from the standard repositories.
> Will try to do it this way:
> https://linuxhint.com/install-qt-5-9-1-qt-creator-4-3-1-ubuntu/
> Cheers
> Bernd
> Am 06.01.2018, 12:46 Uhr, schrieb Andreas Neumann <a.neumann at carto.net>:
>> Hi Bernd,
>> or a missing dependency.
>> Check for any qt5-qt3d packages (there are several) and your 3d
>> functionality might magically appear. Also you need at least qt5.9
>> for it to work. Check if this is satisfied.
>> Andreas
>> On 06.01.2018 12:37, Bernd Vogelgesang wrote:
>>> Hi,
>>> just wanted to try the new 3D functionalities, but surprisingly,
>>> there is no menu item under the View-menu where I read it is supped
>>> to be.
>>> Running ubuntugis-nigthlies on Ubuntu 16.04. Everything else seems
>>> to be in place an running well.
>>> Bug or feature?
>>> Cheers
>>> Bernd
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
