[Qgis-user] Linestring - Select by Location
Finbar Gillen finbar.gillen at vhi.ie
Tue Jan 9 05:35:38 PST 2018
Hi Richard,
Tried the ‘crosses’ option. It also selects polylines where the end point sits outside of the polygon feature.
Regards,
Finbar
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Richard McDonnell
Sent: 09 January 2018 13:02
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Linestring - Select by Location
Finbar,
Crosses should do what you want, if the end point is within the polygon, then the line must cross the Boundary, I have no tied it myself.
Regards,
Richard
On 09/01/2018 12:31, Finbar Gillen wrote:
Hi all,
I am doing a bit of analysis where I want to select all linestrings where their end point falls within a polygon feature. Below are the settings I have used in ‘Select by Location’ Plugin.
[cid:image001.jpg at 01D3894E.BA7B3F10]
Any linestring that falls outside will not be selected, which you would expect. I don’t want to use ‘intersects’ as an option in the plugin as it will create an over selection for what I want to do.
[cid:image002.jpg at 01D3894E.BA7B3F10]
Is there a way where you can specify the linestring end point has to be within a polygon rather than the whole line? I have the x y coordinate for the end point within the attribute table.
Regards
Finbar
Finbar Gillen | Data Analyst
Vhi Healthcare| 2 Custom House Plaza, IFSC, Dublin 1
E : finbar.gillen at vhi.ie<mailto:finbar.gillen at vhi.ie>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://scanmail.trustwave.com/?c=6600&d=rr3U2qwjigj-HM_xj142vMOmVPJzHwbiVKiFGzsPyA&s=33&u=https%3a%2f%2flists%2eosgeo%2eorg%2fmailman%2flistinfo%2fqgis-user>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://scanmail.trustwave.com/?c=6600&d=rr3U2qwjigj-HM_xj142vMOmVPJzHwbiVKiFGzsPyA&s=33&u=https%3a%2f%2flists%2eosgeo%2eorg%2fmailman%2flistinfo%2fqgis-user>
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
[Image removed by sender.]<http://scanmail.trustwave.com/?c=6600&d=rr3U2qwjigj-HM_xj142vMOmVPJzHwbiVKbeTG4Ayw&s=33&u=http%3a%2f%2fwww%2eopw%2eie%2f>
Email Disclaimer: http://www.opw.ie/en/disclaimer/<http://scanmail.trustwave.com/?c=6600&d=rr3U2qwjigj-HM_xj142vMOmVPJzHwbiVPqIQThang&s=33&u=http%3a%2f%2fwww%2eopw%2eie%2fen%2fdisclaimer%2f>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180109/a8d79cb4/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180109/a8d79cb4/attachment.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180109/a8d79cb4/attachment-0001.jpg>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180109/a8d79cb4/attachment-0002.jpg>
