[Qgis-user] ArcSDE
James Wood jwood911 at gmail.com
Tue Jan 9 07:55:01 PST 2018
Thanks Jürgen,
I guess some clarification is in order as to whether this is actually SDE (older) or what is referred to now as Enterprise. There are also levels of Enterprise as well.
Feature classes created through the ArcGIS interface can been seen in the Spatial tab of an SSMS query. I have also connected to SDE (SQL) before from QGIS, however it has been some versions past.
Sorry for jumping the gun before asking Roberto to clarify, and appreciate your input.
James
Sent from my iPhone
> On Jan 9, 2018, at 09:41, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi James,
>> On Tue, 09. Jan 2018 at 09:27:21 -0600, James Wood wrote:
>> It would actually be a SQL or Oracle DBMS connection, whichever your SDE is
>> sitting on top of.
> Really?  I thought SDE would use proprietary data structures in the database
> instead of the database's native geometry representation.
> GDAL has support for SDE that should also be available through QGIS.  There
> used to be SDE GDAL modules in OSGeo4W.  But building those requires ESRI
> libraries that are neither publicly nor - AFAIK - available to SDE customers
> anymore, hence recent builds of GDAL in OSGeo4W don't have SDE support (there's
> some cruft for GDAL 1.5 left).
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
