[Qgis-user] ctrl-c selection issue
Ramon Andinach custard at westnet.com.au
Tue Jan 9 12:58:55 PST 2018
I’m not sure what the problem is, but if I were doing that repeatedly, I’d probably use Layer -> Save As, tick the Save Only Selected Features box and save it to CSV.  Then muck about with excel later.
This way ought to be a bit lighter on the memory.
Ramon.
> On 10 Jan 2018, at 04:25, Jeroen Hovens <mail at groenebij.nl> wrote:
> Hi,
> Using qgis 2.14.18 I have been working today with a large csv file (7.5 mln objects). I just need selections of this database which I can then modify in excel. So I opened the attribute table and made a selection based on a specific value for an attribute, and copied that selection (about 30.000 objects) via the clipboard (ctrl-c) to a new Microsoft Excel file, then saved the excel file and repeated the process for another selection. This worked perfect for some time. However, some selections won’t copy: when I press the copy button the programs turn to ‘not responding’ and won’t snap out of it anymore.  Selection size when this happens is about the same (about 20k to 35k objects).
> What could be the problem? Could the data be corrupted? How can I check what is wrong?
> Thank you
> Gr.
> Jeroen
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180110/eb65f0a3/attachment.html>
