[Qgis-user] Help, please.
kimaidou kimaidou at gmail.com
Tue Jan 16 00:05:59 PST 2018
Hi Tom,
I will try to write in a bigger font.
There is another option that might help you, in QGIS 2.18 : in the status
bar at the bottom of QGIS, you will find beside the scale selector, a tool
to magnify the canvas (where the map is drawn). By default, it is set to
100%, but you can increase it to 200% or more if needed. Be aware that is
is only a magnifier: it will not change the scale, but only increase the
rendering size, so you will see less objects in the map, but bigger.
Regards
Michaël
2018-01-15 19:51 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Dear Tom,
> You can change the font-size and icon-size in menu "Settings" -->
> "Options" --> Tab "General" --> "Font" and "Icon size".
> Hope this helps. Good luck!
> Andreas
> On 15.01.2018 19:32, Tom Koch wrote:
>> I’m a mapmaker with low vision. I’ve just downloaded QGIS for use on a
>> Windows 10 or 11 machine (64 bit). The fonts and icons in the main page
>> (both the menu at the top and the one for adding vectors, rasters, etc. On
>> the left side) are too small for me to see. I tried enlarging the menu
>> bars, etc. But couldn’t enlarge the area or do anything.
>> Please email me (in at least a 12 or 14 point font) how to change the
>> setting so that icons and the fonts for them can be enlarged. I’d be
>> infinitely obliged for the help. Yes, I looked in the documentation but
>> didn’t find any help.
>> Tom koch
>>   tomkoch at kochworks.com
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180116/7ea4586e/attachment.html>
