[Qgis-user] Shape file to xyz where z is label
Stefan Giese Stefan.Giese at wheregroup.com
Sun Jan 21 22:44:30 PST 2018
next step is to right click on your point theme -> save as -> csv and then choose your lithology colum to export...it is easy just try it
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 22.01.2018 um 00:02 schrieb Chas Sheen:
> Stefan,
> It looks at though this generates a shape file of the centroids (pink
> dots below).
> Inline images 1
> What I was after was an xyz file of the data where z is lithology so
> that I can fill the shapefile polygons with a lithology colour/pattern
> in my software.
> Chas
> On 19 January 2018 at 14:56, Stefan Giese (WhereGroup)
> <stefan.giese at wheregroup.com <mailto:stefan.giese at wheregroup.com>> wrote:
>     Hi Chas,
>     you can use Vector-Menu->Geometry Tools->Polygon centroids
>     which will produce a pointlayer with all attributes. There you
>     will find your label as one column like in the geology layer.
>     best
>     stefan
>     Stefan Giese
>     Das WhereGroup-Team wünscht Ihnen ein frohes
>     Weihnachtsfest und ein glückliches Jahr 2018!
>     Die Termine der FOSS Academy für 2018 sind online!
>     Alle Infos unter www.foss-academy.com <http://www.foss-academy.com>
>     Schwimmbadstr. 2
>     79100 Freiburg
>     Germany
>     <tel:%2B49%20%280%29761%20%2F%20519%20102%20-%2061>
>     <tel:%2B49%20%280%29761%20%2F%20519%20102%20-%2011>
>     www.wheregroup.com <http://www.wheregroup.com>
>     Komplementärin:
>     vertreten durch:
>     Am 2018-01-19 06:07, schrieb Chas Sheen:
>         I have a shape file of geology where the label represents
>         lithology.
>         Is there a way to export xyz where z is the label.
>         Then I could display result in other software.
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>         Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180122/9d75c9cc/attachment.html>
