[Qgis-user] Debian/Ubuntu repositories on qgis.org - https vs http
Paolo Cavallini cavallini at faunalia.it
Wed Jan 31 01:06:28 PST 2018
Il 31/01/2018 06:45, Richard Duivenvoorde ha scritto:
> On 30-01-18 23:58, Alister Hood wrote:
>> Hi everyone,
>> I followed the instructions
>> at https://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu to
>> install from https://qgis.org/ubuntugis, and I found that apt-get update
>> gave me "handshake failed" errors unless I used http instead of https.
>> This might be because I am testing under WSL, so not really a normal
>> linux environment, but I just wanted to check - does https normally work
>> for people?
> https://qgis.org/ubuntugis/ is being served via Cloudflare, and you get
> a https certificate via them.
> if you use: https://ubuntu.qgis.org/ubuntugis/ you do NOT go via
> Cloudflare, can you check if that works for you. (and if  maybe do a
> pull request to fix docs?)
I can install esiliy if I install
apt-transport-https
All the best
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
