[Qgis-user] Debian/Ubuntu repositories on qgis.org - https vs http
Jürgen E. Fischer jef at norbit.de
Wed Jan 31 23:07:22 PST 2018
Hi Alister,
On Thu, 01. Feb 2018 at 12:56:32 +1300, Alister Hood wrote:
> It seems Richard is right - https://ubuntu.qgis.org/ubuntugis/ works and
> https://qgis.org/ubuntugis/ does not.
> But Jürgen reported that it does work for him, which is perplexing.
deb	https://qgis.org/debian-nightly		unstable	main
that works for me - just verified that it's not only apt-get update, but also
apt-get install (qgis.org points at a cloudflare)
> When I installed again later in the day (for a later version of Ubuntu),
> from http://qgis.org/ubuntugis-nightly/, I was having problems with the
> packages downloading quite slowly or timing out - I guess the server was
> overloaded. Perhaps the docs should mention both https://ubuntu.qgis.org/
> ubuntugis/ and http://qgis.org/ubuntugis/ if they are on different servers.
The docs shouldn't mention ubuntu.qgis.org (or any *.qgis.org; because
ubuntu.qgis.org is just one name to trigger the wildcard, that leads to the
actual server instead of going through cloudflare).
http://foo.qgis.org/ will work, while https://foo.qgis.org/ won't, because the
later will present the qgis.org certificate that doesn't cover the wildcards
(IIRC letsencrypt didn't support that at least when that was setup).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180201/e73bc62d/attachment.sig>
