[Qgis-user] Issue with joining attributes by location
Stefan Giese Stefan.Giese at wheregroup.com
Wed Jan 31 23:24:51 PST 2018
Hi Neil,
just a note to  your link: if you provide shapefiles, you'll have to put
at least 3 files: CC4a_RegionsSub.shp, CC4a_RegionsSub.dbf and
CC4a_RegionsSub.shx. (shp contains the geometry, dbf the attributes and
shx is the index between shp and dbf)..
best regards
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSS Academy Kompaktkurs Winterschule 2018
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://www.foss-academy.com/schulungstermine/kompaktkurs-winterschule
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 01.02.2018 um 05:42 schrieb Berg, Neil:
> Hi all,
> I’m working with (1) a CSV file containing columns of “lat” and “lon”
> which represent grid cell centroids from a gridded model product over
> California (“loca_lat_lon.csv”), and (2) a shape file that carves up
> California into 12 distinct subregions (“CC4a_RegionsSub.shp”).
> These files can be accessed here:
> https://drive.google.com/drive/folders/1IUrpVSJYBRIoCS4vzGYK9sBEzdwZec-c?usp=sharing
> I am trying to determine which grid cells reside in each of the 12
> subregions (or NA/NULL if outside all subregions) using Vector -> Data
> Management Tools -> Join Attributes by Location. I have specified my
> Target vector layer as loca_lat_lon.csv, the Join vector layer as
> CC4a_RegionsSub.shp, the Geometric predicate as “intersects”, and am
> taking attributes of the first located feature, and only keeping
> matching records.
> The issue is that the returned joined layer assigns just 1 of the 12
> subregions, “Sierra Nevada Mountains”, to all grid cells, rather than
> different subregions (or None) to the cells.
> The shape file has a CRS of NAD83/California Albers and the
> coordinates in the CSV file are simply WGS 84. I’ve tried resetting
> the latter CRS to NAD83/California Albers, but the same issue persists.
> I’m using QGIS 2.18.14.
> Any help is greatly appreciated. Thanks in advance!
> Neil
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180201/290b1031/attachment.html>
