[Qgis-user] Complex Polygons to Simple Polygons
Mike Flannigan mikeflan at att.net
Sat Jul 7 05:32:26 PDT 2018
What I am trying to do is explained by
somebody else here:
https://tinyurl.com/ycl72xlk
https://stackoverflow.com/questions/45096552/converting-a-polygon-with-holes-into-multiple-simple-polygons-without-holes?s=4|132.7784
I believe I can get this done outside of QGIS, but I am
asking you'all if you know of a way to do this with
QGIS.  The videos below describe the problem in more
detail.
A brief description of what I want to do is to reduce complex
polygons (outlined by their nodes) to numerous simple
polygons (outlined by their nodes) that do not include
the "holes" in the complex polygon.
http://www.mflan.com/temp/poly1.wmv
http://www.mflan.com/temp/poly2.wmv
http://www.mflan.com/temp/links.txt
The videos are very similar.  If you watch one
you don't need to watch the other.
Thanks for your attention.
Mike
