[Qgis-user] minimum and recommended specs for a laptop?
Patrick Dunford
enzedrailmaps at gmail.com
Thu Jul 19 22:55:34 PDT 2018
Good afternoon
An i7 CPU is very powerful and will have more than enough capability but
it depends on the exact tasks. I carry out all my mapping with Pentium G
CPUs in my computers (i1 equivalent) with Debian as the OS.
I would think the amount of RAM you have is probably of more
significance than different models of i7. You can also choose a distro
or desktop environment that is resource efficient, currently I prefer
XFCE compared to some of the other resource hungry environments.
You could also consider an SSD as being faster than a regular HDD if
disk swapping may occur.
If your laptop gets too hot it may not be designed for intensive work
and this is probably a factor of the laptop itself not the workload. It
is simply very difficult to fit a cooling solution within most laptop
chassis and a more powerful CPU will need more cooling. A less powerful
CPU may take longer but have less heat output working at full power for
long periods.
On 19/07/18 21:32, Steven Drake wrote:
> Hello,
> I'm thinking of buying a laptop and wondering about the minimum and
> recommended specs for a laptop to run QGIS 3.x? The plan is to use
> Ubuntu as the OS and the laptop for writing scripts, working on
> Process Models, etc... with occasional full blown tests using 'large'
> (+500,000 polygon) shapefiles. My desktop is more than sufficient for
> this but I'm looking for something to use when travelling.
> I used to have a somewhat decent laptop but it is older and gets crazy
> hot... and does not do well with larger shapefiles. The old laptop
> case actually deformed slightly in the hot areas which screams to me
> "fire hazard!" and therefore is no longer used.I'd like to avoid those
> issues with the new laptop.
> The laptops on the market seem to be mainly 7th generation Intel
> processors with a wide variation in performance. Just to keep this
> simple, let's consider i7 types. There are designations ending with a
> "U" which use less power, create less heat and used in lower
> performing computers. Then there are the "H" and "HQ" processors in
> higher end computers which sound more capable and use more power.
> I'm guessing a "U" processor will be overtaxed by the scenario in the
> first paragraph. So *if* it does not crash it will run to the design
> limit and heat up. If using the "H" or "HQ" processors it will likely
> not crash, produce lots of heat but maybe not too much since it is
> designed for such intensive applications?
> Am I understanding the situation correctly? What else might play a
> significant role in the heat issue? What about laptops with built in
> cooling systems beyond the normal fans and heat sinks? And most
> importantly... how to pick a computer / processor / other items
> capable of running QGIS with large datasets? How to find a reasonable
> middle between performance and heat? ...and of course not cost too
> much? Gaming computers????
> Thank you,
> --S
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180720/1b8fdde1/attachment.html>
