[Qgis-user] Georeferenced raster images
Patrick Dunford
enzedrailmaps at gmail.com
Fri Jul 20 22:13:51 PDT 2018
I do this using Gimp to create new composite tiles based on existing
georeferenced contemporary aerial photo map tiles.
I believe there is a georeferencing plugin available but I was unable to
achieve what I needed with it because it didn't appear to be capable of
matching up the coordinates.
On 21/07/18 10:49, Wolstan H M Dixie wrote:
> Hi - I am a new user struggling to pick up the fundamentals - I have
> successfully imported a LIDAR raster layer and hillshaded / pseudo
> coloured / contoured it.
> My problem is that I want an image of a topographical mapĀ behind it as
> a base map to provide context.
> The GIS I am familiar with had the facility to take an image eg TIFF,
> JPG, PNG, georeference the four corners, and import it into a layer so
> that it was matched to the vector map. This seems a simple and I should
> have thought common requirement eg you want to put a TIFF of a historic
> map behind the modern map you are creating.
> I cannot see any way of doing it - am I being obtuse?
> Any help appreciated
> Wolstan
> Qgis-user mailing list
