[Qgis-user] google earth aerial is offset
Phil Wyatt phil at wyatt-family.com
Sat Jul 21 23:10:08 PDT 2018
Hi Boaz,
Are you using Google earth via “Open Layers plugin”? If so, check and see if the offset still exists with QuickMapServices Plugin (with the contributors pack). Is this in the map view or when you do a print via composer.
Some imagery is not well aligned but it varies across the globe. How are you determining that there is an error – from known GPS traces or someone else’s data? Others may know of some way to ‘shift’ the imagery (if you feel that is necessary).
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Boaz Bar Ilan
Sent: Sunday, 22 July 2018 2:50 PM
To: qgis-user
Subject: [Qgis-user] google earth aerial is offset
hi
I use google earth satellite layer
it constantly comes with little offset
what can be done ?
thanks
boaz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180722/81895498/attachment.html>
