[Qgis-user] Georeferencing images
Richard Duivenvoorde rdmailings at duif.net
Sun Jul 22 01:22:03 PDT 2018
There is also the
Freehand raster georeferencer pluguin:
http://plugins.qgis.org/plugins/FreehandRasterGeoreferencer/
as an alternative to do 'easy' visual georeferencing.
I think it is quite promissing
Regards,
On 07/21/2018 09:26 PM, Nicolas Cadieux wrote:
> Hi,
> Play with the placement algorithms.  Start with  the basic Helmert with 2 or more points. Anything more than 2 points and you will see where the distortions come from and give you an idea of what your are dealing with.   Finish with Thin Plate Spline (TPS).
> Nicolas
>> Le 21 juill. 2018 à 14:33, Wolstan H M Dixie <wolstan-dixie at hotmail.co.uk> a écrit :
>> Thanks everyone - I discovered the Plugin! However it takes a bit of
>> practice, and sometimes it fails to position the image correctly - I
>> think it needs more that 4 points, probably about 8, to work properly.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
