[Qgis-user] GPS Live Tracking Problem
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Jul 29 13:04:31 PDT 2018
I am shooting from the hip as I don’t use the plugin. I imagine the plugin creates its own temporary layer. I suspect the layer probably disappears when the plugin is disabled? I imagine there is probably a setting in the plugin that can help you decide where to save the data. Did you try to save the project or to save the layer? (I figure you probably did both.). If not, make sure the layer is in editing mode and saved at the end unless the gps track is somehow saved in the project file.
If the track is saved in a memory layer, then you can download a plugin made to save those temporary memory layers.
If all else fails, contact the plugin programmer and go to the plugin web site if it exists. Hopefully, more people will try to help here.
Cheers!
Nicolas
> Le 29 juill. 2018 à 09:17, Don Parks <dparks58 at gmail.com> a écrit :
> Good Evening,
> My name is Don Parks and I’m a new QGIS user and a novice at GIS. I own a commercial farm and have used QGIS to develop a property map with layers containing roads, trails, fields, buildings, etc. I would like to use my IPhone 8 as a GPS receiver to track movements live and have them appear digitized on a designated map layer and saved as a line feature on that layer. I would also like to establish waypoints this way as well. The documentation indicates that this is possible, but I’m having trouble and would be grateful for some help.
> I’m using QGIS 3.2.0 Bonn. I’m running Windows 10 Home, 64 bit, on a Dell Latitude E6520 with 8 GB of RAM. Per recommendations I found in the QGIS documentation, I’m using GPS 2 IP installed on my phone to enable it to send GPS data to my QGIS software. I’m using the “GPS Information” panel in QGIS as directed.
> I have successfully established a connection between my phone and QGIS. Per some instructions I found in the QGIS documentation regarding Live GPS Tracking, I created a new vector line layer (Shapefile type) and enabled editing for that layer and highlighted it in the Layers Panel. I then traveled around the property and, as hoped, a line was created on the map live as I moved. At the completion of the route I attempted to save changes. However, this is where I encountered the problem. What I noticed first was that the line created by the GPS track was not “attached” to any layer. If I unchecked all layers, the line was still there on the white map canvas. And I could not get rid of it unless I closed and re-opened QGIS…at which time it would go away. On the other hand, I cannot save it either. It does not appear to be attached to any layer nor can I save it the layer I created or any other layer. I’ve tried deleting and creating a new vector layer, but I get the same results. Everything seems to be working to get the track into QGIS, but I just can’t get it associated with and saved on a layer.
> I’m very impressed with QGIS and our property map has already been a valuable tool for us. This GPS tracking ability would be very useful and I would very much appreciate any help. Thank you in advance for you willingness to help a beginner.
> Sincerely,
> Don Parks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180729/e2e78eb5/attachment.html>
