[Qgis-user] GDAL producing DEMs that do not load in QGIS 2.18 on Ubuntu but fine on Windows
Cliff Patterson cliffpatterson at gmail.com
Mon Jul 30 08:13:25 PDT 2018
I am producing DEMs from LiDAR data using gdal_grid. All processes compete
fine, but the resulting DEM does not load into QGIS 2.18 on my Ubuntu 16.04
machine but they load fine on my Windows machines (same version of QGIS).
When I look at layer properties on Ubuntu machine, the overviews that are
produced are not recognized and when I try to rebuild within QGIS, I get an
error that I cannot produce overviews for this file type -- it's a Geotif.
DEM is produced using the following:
gdal_grid -zfield field_3 -a nearest:radius1=20:radius2=20 -a_srs
epsg:26916 -txe 607900.7    648882.51 -tye 5322415.07 5349297.05 -outsize
40981.81 26881.98 -co "BIGTIFF=YES" -co "COMPRESS=LZW" --config -a_nodata 0
-l ground2 ground2.vrt ground2_grid_1m_nearest_radius20.tif --config
GDAL_NUM_THREADS ALL_CPUS --config GDAL_CACHEMAX 2000
I then turn 0s into NoData with Gdal_calc
gdal_calc.py --co="COMPRESS=LZW" -A ground2_grid_1m_nearest_radius20.tif
--outfile=ground2_grid_1m_nearest_radius20_nodata0.tif --calc="A*(A>0)"
--NoDataValue=0
Then I build overviews with gdaladdo
gdaladdo -clean --config COMPRESS_OVERVIEW LZW --config INTERLEAVE_OVERVIEW
PIXEL -r average ground2_grid_1m_nearest_radius20_nodata0.tif 2 4 8 16 32
64 128 256 512 1024
Gdalinfo says....
Driver: GTiff/GeoTIFF
Files: ground2_grid_1m_nearest_radius20_nodata0.tif
Size is 40981, 26881
Coordinate System is:
PROJCS["NAD83 / UTM zone 16N",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            TOWGS84[0,0,0,0,0,0,0],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-87],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","26916"]]
Origin = (607900.699999999953434,5322415.070000000298023)
Pixel Size = (1.000019765257072,1.000036456977029)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  607900.700, 5322415.070) ( 85d33' 8.00"W, 48d 2'45.22"N)
Lower Left  (  607900.700, 5349297.050) ( 85d32'43.44"W, 48d17'15.62"N)
Upper Right (  648882.510, 5322415.070) ( 85d 0' 9.50"W, 48d 2'15.55"N)
Lower Right (  648882.510, 5349297.050) ( 84d59'35.63"W, 48d16'45.69"N)
Center      (  628391.605, 5335856.060) ( 85d16'24.08"W, 48d 9'46.71"N)
Band 1 Block=40981x1 Type=Float64, ColorInterp=Gray
  NoData Value=0
  Overviews: 20491x13441, 10246x6721, 5123x3361, 2562x1681, 1281x841,
641x421, 321x211, 161x106, 81x53, 41x27
So as you can see, overviews are produced and the raster is comrpessed with
LZW. But... it will not load in QGIS and causes it to crash (on Ubuntu).
Loads great on Widows... (boo!)
Thoughts?
Cliff
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180730/9f765008/attachment.html>
