[Qgis-user] Digitizing points with azimuth and distance
Alexandre Neto senhor.neto at gmail.com
Mon Mar 5 04:02:04 PST 2018
You can use the Advanced digiting panel with snapping.
Use construction mode to put the reference point, leave the construction
mode, then lock the distance and azimuth to the desired values.
Alex Neto
Adena Culture <adenaculture at gmail.com> escreveu no dia segunda, 5/03/2018
às 11:49:
> ShapTools does this in part. Let me know if there is more you need.
> Sent from my iPod
> On Mar 5, 2018, at 3:20 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> > Hi all,
> > I cannot recall an easy solution for this problem:
> > * clicking on a point
> > * adding azimuth an distance
> > * automatically creating a point, in a second layer, at the distance and
> > azimuth specified
> > * repeat the procedure, adding more point to the same second layer.
> > Anyone has a good solution to this?
> > All the best, and thanks.
> > Paolo Cavallini - www.faunalia.eu
> > QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> > https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180305/99aafeb4/attachment.html>
