[Qgis-user] Digitizing points with azimuth and distance
Alexandre Neto senhor.neto at gmail.com
Mon Mar 5 09:18:42 PST 2018
Paolo Cavallini <cavallini at faunalia.it> escreveu no dia segunda, 5/03/2018
às 16:27:
> Il 05/03/2018 13:02, Alexandre Neto ha scritto:
> > You can use the Advanced digiting panel with snapping.
> > Use construction mode to put the reference point, leave the construction
> > mode, then lock the distance and azimuth to the desired values.
> Ola Alexandre,
> thanks for the suggestion. The reference points are already there. I
> tried the AD panel, but I was able to use it only to build lines, not
> points - am I missing something?
> All the best.
You can digitize all type of layers, including points. here's a small
screencast example.
https://imgur.com/a/embqz
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180305/8438d73b/attachment.html>
