[Qgis-user] Digitizing points with azimuth and distance
Paolo Cavallini
cavallini at faunalia.it
Mon Mar 5 23:04:39 PST 2018
Il 06/03/2018 00:36, Nyall Dawson ha scritto:
> Not sure if it helps - but 3.2 has an inbuilt "project points"
> processing algorithm which allows you to shift the points from an
> input layer by a given bearing and distance (also supports
> data-defined/expression based bearing/distance values).
thanks - it would help in case projecting data are stored in a table. In
our specific case, it was requested to insert one by one interactively.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
