[Qgis-user] QGIS 3.0 with GRASS 7.4.0 looking for 7.2.0?
Philip Barlow
philipb at pembrokeshirecoast.org.uk
Tue Mar 6 03:55:41 PST 2018
Hi all,
I'm experiencing a slightly odd issue with QGIS 3.0 and GRASS in Windows 10 installed with OSGEO4W. The GRASS plugin seems to functioning just fine but if I attempt to use any GRASS algorithms from the processing toolbox I get an error message:
"The specified GRASS 7 folder "C:\OSGEO4~1\apps\grass\grass-7.2.1\bin" does not contain a valid set of GRASS 7 modules. Please, go to the Processing settings dialog, and check that the GRASS 7 folder is correctly configured"
So I go to the providers settings and the path is set to ...\grass-7.4.0\bin. So why is QGIS still looking for the modules in the 7.2.1 folder, which subsequently, doesn't actually exist. Is this a bug? Is the path hard coded?
I have 2.18.17 installed alongside, this also uses the 7.4.0 path and the processing tools for GRASS are working fine.
Any thoughts?
Cheers
Phil
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180306/6e9d9405/attachment.html>
