[Qgis-user] QGIS custom python function with zero or more args
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Fri Mar 9 02:25:10 PST 2018
Hi Benjamin,
you can do it like this example which only makes a sum of 2 values. Two
aruments or only one...:
@qgsfunction(-1, 'Python')
def add_values( values, feature, parent):
	if len(values) == 2:
		return values[0]+values[1]
	elif len(values) == 1:
		return values[0]+5
@qgsfunction(-1, 'Python') says that you will pass a list of arguments
and the function will be in the Python rider.
In the code, you can check the number of arguments with getting the
length of the list, and then use your default values...
hope this helps
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Treffen Sie uns auf der
FOSSGIS Konferenz 2018
21.-24. März 2018 in Bonn
https://fossgis-konferenz.de/2018/
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 2018-03-09 09:18, schrieb Fuenfer-Koenigstein.Benjamin2 at swm.de:
> Hi all,
> I would like to write a custom python function for QGIS 2.18 that
> takes zero or one argument. The reason is that in most cases I can use
> a default value in the function, in some cases I would like to enter
> the value as argument. For python I know that you can prefix args in
> functions to make them optional, e.g. def func(*arg). For QGIS
> functions this will not work because there always have to be the args
> feature and parent in last two positions. Has anyone experience with
> QGIS functions that take zero or more arguments? Thanks for any help!
> Regards
> Benjamin
> Qgis-user mailing list
