[Qgis-user] Auxillary storage fields and field calculator
Martin martin at mstubbs.co.uk
Sun Mar 11 01:30:10 PST 2018
I have a postgis dataset that currently has sets of label x , y and rotations
for different projects. Moving to QGIS 3 I would like to remove these fields
and use auxillary storage instead.
I have created the auxillary storage fields and I would like to use the field
calculator to copy the data from the label_x fields in the potgis dataset into
the new fields. When I try to "Update existing field" the auxillary storage
fields are not listed. I can use them as inputs to an expression but not as
outputs.
I couldn't find this discussed so not sure if this is a known limitation.
Thanks for the help.
Martin
