[Qgis-user] ERDAS ECW/JPEG2000 SDK
Jesús Lopez jesusl.temez at gmail.com
Mon Mar 12 11:34:55 PDT 2018
ECW not even appear in the list….
In GDAL 2.2 folder I have two subfolders, Libraries and Plugins. In the first libNCSEcw.dylib file and in the second gdal_ECW_JP2ECW.dylib file. I don’t know if this is correct...
> El 12 mar 2018, a las 19:17, William Kyngesburye <kyngchaos at kyngchaos.com> escribió:
> Try running this in a Terminal:
> gdalinfo --formats
> You should get a list of supported formats.  If ECW is not near the top, hopefully you'll see an error to say why.
>> On Mar 12, 2018, at 1:10 PM, Jesús Lopez <jesusl.temez at gmail.com <mailto:jesusl.temez at gmail.com>> wrote:
>> Qgis not read the ECW, not a valid data source says...
>>> El 12 mar 2018, a las 19:03, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> escribió:
>>> Is there one part of the installation that is reporting a problem, or is QGIS just not recognizing ECW?
>>>> On Mar 12, 2018, at 10:51 AM, Jesús Lopez <jesusl.temez at gmail.com <mailto:jesusl.temez at gmail.com>> wrote:
>>>> Hi William. Thanks a lot for your work. This procedure works in Qgis 3?? I'm trying installing the plugin and the lib in GDAL 2.2 folder but I can’t get it to work…
>>>> Jesus
>>>>> El 12 mar 2018, a las 15:09, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> escribió:
>>>>> No, you should download the specified SDK version, 5.3.  Since it's C++, it's easy to get missing symbol errors, even if the API doesn't change.
>>>>> Note that the latest plugin has updated instructions, including the corrected download link.
>>>>>> On Mar 12, 2018, at 5:19 AM, Dave Pepper <pepdave at gmail.com <mailto:pepdave at gmail.com>> wrote:
>>>>>> Hi
>>>>>> After reading QGIS user archive here and
>>>>>> https://gis.stackexchange.com/questions/124794/installing-qgis-with-ecw-support-on-mac <https://gis.stackexchange.com/questions/124794/installing-qgis-with-ecw-support-on-mac>
>>>>>> I see that this problem of reading ecw files in QGIS has some history.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
>>> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
>>> - Marvin
> "Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180312/e4ba1fac/attachment.html>
