[Qgis-user] ERDAS ECW/JPEG2000 SDK
Jesús Lopez jesusl.temez at gmail.com
Mon Mar 12 14:58:31 PDT 2018
Ah, ok. Will wait for it. Thanks again for all your effort!
> El 12 mar 2018, a las 20:25, William Kyngesburye <woklist at kyngchaos.com> escribió:
> Oh wait, GDAL 2.2 - I don't have the GDAL plugins ready yet for 2.2.  2.1 plugins won't work for 2.2.
>> On Mar 12, 2018, at 1:34 PM, Jesús Lopez <jesusl.temez at gmail.com <mailto:jesusl.temez at gmail.com>> wrote:
>> ECW not even appear in the list….
>> In GDAL 2.2 folder I have two subfolders, Libraries and Plugins. In the first libNCSEcw.dylib file and in the second gdal_ECW_JP2ECW.dylib file. I don’t know if this is correct...
>>> El 12 mar 2018, a las 19:17, William Kyngesburye <kyngchaos at kyngchaos.com <mailto:kyngchaos at kyngchaos.com>> escribió:
>>> Try running this in a Terminal:
>>> gdalinfo --formats
>>> You should get a list of supported formats.  If ECW is not near the top, hopefully you'll see an error to say why.
>>>> On Mar 12, 2018, at 1:10 PM, Jesús Lopez <jesusl.temez at gmail.com <mailto:jesusl.temez at gmail.com>> wrote:
>>>> Qgis not read the ECW, not a valid data source says...
>>>>> El 12 mar 2018, a las 19:03, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> escribió:
>>>>> Is there one part of the installation that is reporting a problem, or is QGIS just not recognizing ECW?
>>>>>> On Mar 12, 2018, at 10:51 AM, Jesús Lopez <jesusl.temez at gmail.com <mailto:jesusl.temez at gmail.com>> wrote:
>>>>>> Hi William. Thanks a lot for your work. This procedure works in Qgis 3?? I'm trying installing the plugin and the lib in GDAL 2.2 folder but I can’t get it to work…
>>>>>> Jesus
>>>>>>> El 12 mar 2018, a las 15:09, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> escribió:
>>>>>>> No, you should download the specified SDK version, 5.3.  Since it's C++, it's easy to get missing symbol errors, even if the API doesn't change.
>>>>>>> Note that the latest plugin has updated instructions, including the corrected download link.
>>>>>>>> On Mar 12, 2018, at 5:19 AM, Dave Pepper <pepdave at gmail.com <mailto:pepdave at gmail.com>> wrote:
>>>>>>>> Hi
>>>>>>>> After reading QGIS user archive here and
>>>>>>>> https://gis.stackexchange.com/questions/124794/installing-qgis-with-ecw-support-on-mac <https://gis.stackexchange.com/questions/124794/installing-qgis-with-ecw-support-on-mac>
>>>>>>>> I see that this problem of reading ecw files in QGIS has some history.
>>>>>> _______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180312/aac5055f/attachment.html>
