[Qgis-user] Exporting the browsers XYZ Tiles layers to another PC?
Alessandro Pasotti apasotti at gmail.com
Tue Mar 13 07:36:05 PDT 2018
0. add at least one XYZ layer
1. in QGIS3 Go to Settings -> User Profiles -> Open Active User Profile
Folder.
2. close QGIS3
3. in the a.m. folder change dir to QGIS
4. open QGIS3.ini with a text editor
5. search for connections-xyz
you should figure out how it works, every connection has several
configuration lines, for example:
connections-xyz\OSM\authcfg=
connections-xyz\OSM\password=
connections-xyz\OSM\referer=
connections-xyz\OSM\url=http://a.tile.openstreetmap.org/{z}/{x}/{y}.png
connections-xyz\OSM\username=
connections-xyz\OSM\zmax=18
connections-xyz\OSM\zmin=0
The connection name in the example above is "OSM"
Hope this helps.
6. add your connections
7. restart QGIS
On Tue, Mar 13, 2018 at 11:13 AM, magerlin <MAP at ramboll.dk> wrote:
> I have an old PC where I have manually added more than 10 tile maps in the
> Browsers XYZ Tiles (called "Tile Server (XYZ)" in Qgis2).
> Now transferring to a new PC I would love not to have to manually create
> all
> the layers again.
> Is there any way to export the layer setup from the old PC or any settings
> file I could manipulate?
> Regards Morten
> Currently using Qgis 2.18.16 (OSGeo4),
> Windows 7, 64bit
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180313/c6895533/attachment.html>
