[Qgis-user] Atlas Map Book Design
Springfield Harrison stellargps at gmail.com
Sun Mar 18 10:21:27 PDT 2018
Okay, thanks Andreas. I appreciate your advice. It sounds like the
reporting mode does not replace the atlas, is that correct? So maybe the
atlas feature in both versions is the same? I don't know if I need the
reporting mode for multi-page maps.
And regarding the versions, not sure why one would have old and new running
in parallel, especially if they are not backwards compatible.
The new plug-ins for version 3, are there many of them or is that a slow
transition?  Overall, I have found version 2 plugins to be disappointing,
although there have been some exceptions. With many, it is not clear what
they are going to do or how to use them.
I find I am returning to Manifold GIS more and more to accomplish certain
things reliably.
Thanks again Andreas...
Cheers . . . . .   Spring
Samsung Tab 4
On Mar 18, 2018 10:12 AM, "Andreas Neumann" <a.neumann at carto.net> wrote:
> About your other question: QGIS 3 also contains the Atlas mode from
> version 2.18 - but the reporting mode exists in parallel to the normal
> layout and atlas printing. So you have more choice. I am not experienced
> with the reporting mode until now - but I will definitely try it soon.
> Andreas
> On 18.03.2018 17:58, Springfield Harrison wrote:
> Thank you, but no I haven't. I'm very leery of upgrading, especially when
> I read all the sad stories how about components not working and
> installations going sideways.
> If this upgrade to Windows 7 is Bulletproof, maybe I'll give it a try. I
> have always been confused by the plethora of installation options for this
> software.
> Does the new reporting mode still include the atlas / multi-page printing?
> Samsung Tab 4
> On Mar 18, 2018 9:49 AM, "Andreas Neumann" <a.neumann at carto.net> wrote:
>> Hi Harrison,
>> Have you tried the new reporting mode in QGIS 3? It is pretty new - so
>> maybe it doesn't fit all requirements yet - but it allows you to have
>> section titles, footers and headers, etc. Maybe worth a try?
>> Greetings,
>> Andreas
>> On 18.03.2018 15:38, Springfield Harrison wrote:
>>> Hello All,
>>> I am able to create map books using the Atlas feature but do not need
>>> the title block (text box) on every page.
>>> Is there a method to control the content of each page (as in Manifold
>>> GIS?)?
>>> Thanks very much . . . .
>>> Cheers . . . . . Springfield Harrison
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180318/54db5532/attachment.html>
