[Qgis-user] DB Manager cannot connect to PostGIS (error with traceback)
Luigi Pirelli luipir at gmail.com
Mon Mar 19 03:28:42 PDT 2018
yes sorry... not yet merged, and the PR have to be aligned to the current code
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On 19 March 2018 at 11:22, G. Allegri <giohappy at gmail.com> wrote:
> Thanks Luigi,
> I already tried removing it manually, but it's created again every time.
> So, does this mean that DB Manager for PostGIS on QGIS 3/Windows is
> currently broken?
> Giovanni
> 2018-03-19 11:07 GMT+01:00 Luigi Pirelli <luipir at gmail.com>:
>> you can safetly remove
>> C:/Users/giohappy/AppData/Local/Temp/tmp_basic_{4703a7e8-5f5a-44ec-b490-7fd4ec0e9f7f}.pem
>> and try again
>> btw it was fixed since in month in 2-18
>> https://github.com/qgis/QGIS/pull/5477
>> but port to 3.0 was stopped https://github.com/qgis/QGIS/pull/5599 due
>> Boundless closed the QGIS team and I forgot it
>> Luigi Pirelli
>> On 19 March 2018 at 10:59, G. Allegri <giohappy at gmail.com> wrote:
>> > Hi all,
>> > I'm facing the following issue with QGIS 3.1.0 (10044fb1dd) on Windows
>> > 10.
>> > I can define a connection to my local PG, using basic authentication,
>> > and I
>> > can access data from Browser.
>> > If I try to open the connection from DB Manager I obtain;
>> > Traceback (most recent call last): File
>> > "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_model.py",
>> > line
>> > 441, in rowCount self._refreshIndex(parent, True) File
>> > line
>> > 490, in _refreshIndex if item.populate(): File
>> > line
>> > 167, in populate if not connection.connect(): File
>> > "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_plugins\postgis\plugin.py",
>> > line 103, in connect return self.connectToUri(uri) File
>> > "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_plugins\plugin.py",
>> > line 109, in connectToUri self.db = self.databasesFactory(self, uri)
>> > File
>> > line 70, in databasesFactory return PGDatabase(connection, uri) File
>> > line 111, in __init__ Database.__init__(self, connection, uri) File
>> > line 218, in __init__ self.connector = self.connectorsFactory(uri) File
>> > line 114, in connectorsFactory return PostGisDBConnector(uri) File
>> > "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_plugins\postgis\connector.py",
>> > line 128, in __init__ os.remove(sslCAFile) PermissionError: [WinError 5]
>> > Access denied:
>> > 'C:/Users/giohappy/AppData/Local/Temp/tmp_basic_{4703a7e8-5f5a-44ec-b490-7fd4ec0e9f7f}.pem'
>> > I've tried removing and recreating the auth credentials.
>> > I've tried also running QGIS as administrator.
>> > Nothing seems to work...
>> > Is it a known bug?
>> > Giovanni
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
