[Qgis-user] DB Manager cannot connect to PostGIS (error with traceback)
G. Allegri
giohappy at gmail.com
Mon Mar 19 06:05:16 PDT 2018
Well, I don't know if they're inclined to do it but it would nice to know
how they want to manage it...
This is a severe bug for Windows.
Giovanni
Il lun 19 mar 2018, 13:34 Luigi Pirelli <luipir at gmail.com> ha scritto:
> he PR was from Boundless repo, make sense to ask to boundless if they
> want to continue to support QGIS porting patches to 3.0?
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On 19 March 2018 at 11:28, Luigi Pirelli <luipir at gmail.com> wrote:
> > yes sorry... not yet merged, and the PR have to be aligned to the
> current code
> > Luigi Pirelli
> > On 19 March 2018 at 11:22, G. Allegri <giohappy at gmail.com> wrote:
> >> Thanks Luigi,
> >> I already tried removing it manually, but it's created again every time.
> >> So, does this mean that DB Manager for PostGIS on QGIS 3/Windows is
> >> currently broken?
> >> Giovanni
> >> 2018-03-19 11:07 GMT+01:00 Luigi Pirelli <luipir at gmail.com>:
> >>> you can safetly remove
> C:/Users/giohappy/AppData/Local/Temp/tmp_basic_{4703a7e8-5f5a-44ec-b490-7fd4ec0e9f7f}.pem
> >>> and try again
> >>> btw it was fixed since in month in 2-18
> >>> https://github.com/qgis/QGIS/pull/5477
> >>> but port to 3.0 was stopped https://github.com/qgis/QGIS/pull/5599 due
> >>> Boundless closed the QGIS team and I forgot it
> >>> Luigi Pirelli
> >>> * Stackexchange:
> >>> On 19 March 2018 at 10:59, G. Allegri <giohappy at gmail.com> wrote:
> >>> > Hi all,
> >>> > I'm facing the following issue with QGIS 3.1.0 (10044fb1dd) on
> Windows
> >>> > 10.
> >>> > I can define a connection to my local PG, using basic authentication,
> >>> > and I
> >>> > can access data from Browser.
> >>> > If I try to open the connection from DB Manager I obtain;
> >>> > Traceback (most recent call last): File
> >>> > "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_model.py",
> >>> > line
> >>> > 441, in rowCount self._refreshIndex(parent, True) File
> >>> > line
> >>> > 490, in _refreshIndex if item.populate(): File
> >>> > line
> >>> > 167, in populate if not connection.connect(): File
> "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_plugins\postgis\plugin.py",
> >>> > line 103, in connect return self.connectToUri(uri) File
> "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_plugins\plugin.py",
> >>> > line 109, in connectToUri self.db = self.databasesFactory(self, uri)
> >>> > File
> >>> > line 70, in databasesFactory return PGDatabase(connection, uri) File
> >>> > line 111, in __init__ Database.__init__(self, connection, uri) File
> >>> > line 218, in __init__ self.connector = self.connectorsFactory(uri)
> File
> >>> > line 114, in connectorsFactory return PostGisDBConnector(uri) File
> "C:/OSGEO4~1/apps/qgis-dev/./python/plugins\db_manager\db_plugins\postgis\connector.py",
> >>> > line 128, in __init__ os.remove(sslCAFile) PermissionError:
> [WinError 5]
> >>> > Access denied:
> 'C:/Users/giohappy/AppData/Local/Temp/tmp_basic_{4703a7e8-5f5a-44ec-b490-7fd4ec0e9f7f}.pem'
> >>> > I've tried removing and recreating the auth credentials.
> >>> > I've tried also running QGIS as administrator.
> >>> > Nothing seems to work...
> >>> > Is it a known bug?
> >>> > Giovanni
> >>> > _______________________________________________
> >>> > Qgis-user mailing list
> >>> > Qgis-user at lists.osgeo.org
> >>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180319/efe72ff3/attachment.html>
