[Qgis-user] Grass not found
Jean-Baptiste Desbas jb.desbas at gmail.com
Tue Mar 20 00:28:47 PDT 2018
Hello,
Maybe check if you use the "with GRASS" shortcuts (bin\qgis-bin-g7.4.0.exe)
I also had some issues with GRASS algorithms when I used geopackage layer
as inputs.
Regards,
2018-03-19 20:57 GMT+01:00 <jehdukeegr at gmail.com>:
> Thanks William.
> I downloaded the update and am still having the same issues.
> Other ideas?  Thanks guys!
> On Mon, Mar 19, 2018 at 1:51 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
>> I just uploaded an update yesterday that should fix this.  At least the
>> 2nd error.  The first error could be a bigger problem due to my using a
>> space in the QGIS app name (there may be a path quoting issue in the GRASS
>> internals).
>> On Mar 19, 2018, at 2:15 PM, jehdukeegr at gmail.com wrote:
>> Hi,
>> I'm a new Qgis user.  Here are the details:
>> Qgis version  3.0.0 (Downloaded 3/17)
>> MAC OS 10.12.6 (Sierra)
>> I'm trying to use Grass to do some shortest distance network calculations
>> and I receive the following error messages:
>> /var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_
>> 8f76fdc70e874abb92d2ebbbef92c2d3/grassdata/temp_location/PERMANENT:
>> /Applications/QGIS: No such file or directory
>> and
>> The following layers were not correctly generated.
>>    - /var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_
>>    8f76fdc70e874abb92d2ebbbef92c2d3/d24dd229b47946bb8d89c4b98af
>>    4e5fe/output.shp
>> After searching around I've tried updating the directories in GRASS
>> options as suggested here:
>> https://gis.stackexchange.com/questions/219808/finding-grass
>> -module-after-upgrading-qgis-mac
>> Still no dice.  Now I also get the following error when starting Qgis:
>> GRASS init error: GRASS was not found in '/Applications/QGIS
>> 3.app/Contents/MacOS/grass7' (GISBASE), provider and plugin will not work.
>> Any ideas?
>> Thanks in advance.  Otherwise, this is way better than my old ArcGIS
>> packages.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "This is a question about the past, is it? ... How can I tell that the
>> past isn't a fiction designed to account for the discrepancy between my
>> immediate physical sensations and my state of mind?"
>> - The Ruler of the Universe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180320/f8c792b3/attachment.html>
