[Qgis-user] Using processing algorithms from the console in QGIS 3.0
Havard Tveite
havard.tveite at nmbu.no
Thu Mar 22 01:20:48 PDT 2018
QgsApplication.processingRegistry().algorithms() does not
list grass7:v.to.rast.value (but grass7:v.to.rast is
there).
In QGIS 3, the following seems to work:
myres = processing.run("qgis:union", {'INPUT': "my_input", 'OVERLAY':
"my_overlay", 'OUTPUT': "my_result"}, feedback=None)['OUTPUT']
processing.algorithmHelp("qgis:union") describes the
parameters of the algorithm.
Parameter names are case sensitive (at least on Ubuntu).
Håvard
On 21. mars 2018 17:46, Stephen Bosch wrote:
> Hello,
> I am running QGIS 3.0.0 in Linux.
> I'm trying to migrate some pyqgis code from 2.14 to 3.0 and discovering
> the hard way that just about everything has changed :)
> (Unfortunately, the docs haven't been updated yet and the API docs are
> pretty sparse.)
> Say I have this command, which worked in 2.x:
> file_grid_r = processing.runalg("grass7:v.to.rast.value", grid_v, 0, 1,
> extent, 0.008333, -1, 0.000100, None)['output']
> processing.runalg() doesn't exist anymore, apparently it was replaced
> with processing.run(). However, this:
> file_grid_r = processing.run("grass7:v.to.rast.value", grid_v, 0, 1,
> does not work as expected. In the PyCharm debugger, I receive this error
> message:
> sys:1: ResourceWarning: unclosed <socket.socket fd=3,
> family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0,
> laddr=('127.0.0.1', 50386), raddr=('127.0.0.1', 40183)>
> (If the command syntax is in fact correct, then perhaps the algorithm is
> not accessible?)
> My questions:
> * Is there up-to-date console documentation for the Processing toolbox
> somewhere?
> * How can I get a listing of the available algorithms in the same
> format as in 2.x?
> * How do I convert the algorithm calls (processing.runalg) from 2.x to
> 3.x?
> Thanks
> Stephen
> Qgis-user mailing list
Håvard Tveite
Faculty of Science and Technology, NMBU
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 67231548 Web: http://www.nmbu.no
