[Qgis-user] Mac QGIS 3 GRASS fix
William Kyngesburye
woklist at kyngchaos.com
Thu Mar 22 11:10:38 PDT 2018
What are you doing? GRASS plugin tools or Processing GRASS algorithms?
Nothing should be trying to write to the GRASS dir. There should not be permissions problem reading from the GRASS dir.
> On Mar 22, 2018, at 11:00 AM, jehdukeegr at gmail.com wrote:
> Thanks William. I'm still getting some sort of error using grass. Not sure if this is still related.
> /var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_7fd31b05f63f437c84dee066f864d9f9/grassdata/temp_location/PERMANENT: /Applications/QGIS3.app/Contents/MacOS/grass/etc/colors/grass: Permission denied
> On Thu, Mar 22, 2018 at 8:36 AM, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
> The non-working GRASS in the Mac QGIS 3 should be fixed now. It appears the GRASS internals still don't like spaces in the path to GRASS -- this came from my adding "3" to the QGIS app name with a space. The app is now without a space, "QGIS3.app".
> It looks like the missing SAGA is also fixed by the rebuild (don't know why, it just happened).
> REMINDER: My QGIS 3 package requires the python.org <http://python.org/> Python 3. Other distributions/installations of Python are not supported (ie Homebrew, Macports, Anaconda...).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
All generalizations are dangerous, even this one.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180322/9028b258/attachment.html>
