[Qgis-user] QGIS3 Processing Clip
Drexel Peter Peter.Drexel at vorarlberg.at
Fri Mar 23 03:30:38 PDT 2018
Hi all,
In QGIS 3.0 I use native:clip in processing to clip a Shapefile with another shapefile.
The Import-Shapefile contains some invalid polygons so I get an error
________
Processing algorithm...
AlgorithmDialog
Input parameters:
{ 'INPUT' : 'V:/Geodaten/Wasser/Einzugsgebiete/Vlbg_Umgebung/Einzugsgebiete_FGW/ezg_gesamt1_bearbeitet_3D_name.shp', 'OVERLAY' : 'C:/temp/QGIS3/Clip-Maske.shp', 'OUTPUT' : 'memory:' }
Feature (0) has invalid geometry. Please fix the geometry or change the Processing setting to the "Ignore invalid input features" option.
Execution failed after 0.35 seconds
Loading resulting layers
Algorithm 'Clip' finished
______________
In the Log-section of the Clip-Tool.
But where can change the setting to "Ignore invalid input features"?
Thanks
Peter
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180323/d9877336/attachment.html>
