[Qgis-user] QGIS3 Mac Grass error
knussear knussear at mac.com
Tue Mar 27 07:39:04 PDT 2018
Trying to run an edge detection on a gtiff with the i.zc grass module.
Getting the following error. Any thoughts on how to fix?
Processing algorithm…
AlgorithmDialog
Input parameters:
{ 'input' : '/Users/knussear/Research/Classes/Geog 407 Advanced GIS/Fall
2017 KN/Lectures/Processing/ndvi/ndvitst2_index_ndvi.tif', 'width' : 9,
'threshold' : 10, 'orientations' : 2, 'output' :
'/var/folders/5n/ct7t4pbx3b71r1wj5vcc3tgw0000gn/T/processing_91fb1e9f97d640bc9348876bac49ddfb/5f0801db158d48b6a0d896426863451e/output.tif',
'GRASS_REGION_PARAMETER' : '', 'GRASS_REGION_CELLSIZE_PARAMETER' : 0,
'GRASS_RASTER_FORMAT_OPT' : '', 'GRASS_RASTER_FORMAT_META' : '' }
g.proj -c proj4="+proj=utm +zone=11 +datum=WGS84 +units=m +no_defs"
r.external input="/Users/knussear/Research/Classes/Geog 407 Advanced
GIS/Fall 2017 KN/Lectures/Processing/ndvi/ndvitst2_index_ndvi.tif" band=1
output="rast_5aba56ef784465" --overwrite -o
g.region n=4408682.2852300005 s=4408487.032900001 e=301063.33025
w=300841.31027 res=0.10100999999999215
i.zc input=rast_5aba56ef784465 width=9 threshold=10 orientations=2
output=output0724be7b70c945f7b0d70630daca8dce --overwrite
g.region raster=output0724be7b70c945f7b0d70630daca8dce
r.out.gdal -t -m input="output0724be7b70c945f7b0d70630daca8dce"
output="/var/folders/5n/ct7t4pbx3b71r1wj5vcc3tgw0000gn/T/processing_91fb1e9f97d640bc9348876bac49ddfb/5f0801db158d48b6a0d896426863451e/output.tif"
format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
/var/folders/5n/ct7t4pbx3b71r1wj5vcc3tgw0000gn/T/processing_91fb1e9f97d640bc9348876bac49ddfb/grassdata/temp_location/PERMANENT:
/Applications/QGIS3.app/Contents/MacOS/grass/etc/colors/grass: Permission
denied
denied
Execution completed in 0.39 seconds
Results:
{'output': <QgsProcessingOutputLayerDefinition
{'sink':/var/folders/5n/ct7t4pbx3b71r1wj5vcc3tgw0000gn/T/processing_91fb1e9f97d640bc9348876bac49ddfb/5f0801db158d48b6a0d896426863451e/output.tif,
'createOptions': {'fileEncoding': 'System'}}>}
Loading resulting layers
The following layers were not correctly generated.
You can check the 'Log Messages Panel' in QGIS main window to find more
information about the execution of the algorithm.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
