[Qgis-user] Can't install / use NTv2 grid file.
tomi_w foren.thomas at thomas-wunder.de
Wed Mar 28 06:57:12 PDT 2018
Hello Jürgen, Hello Martin,
first of all, thank you very much for your answers. I was unaware of the
fact, that it's necessary to register grid files manually. Following your
suggestions, I tried to add my gsb file to that tbl_datum_transform, however
I haven't managed to make it show up in the "Select datum transformations"
dialog for some reason. This table has many columns that leave me with quite
some uncertainty as to how to gsb file would be configured correctly.
Maybe it's obvious to you...
30001|100017|5678|4647|9615|oberfranken.gsb|||||||BY-KanU-Transformation
(vorlaeufig) von der bayerischen Vermessungsverwaltung||1|0|
30002|100018|4314|4647|9615|oberfranken.gsb|||||||BY-KanU-Transformation
30003|100019|32468|4647|9615|oberfranken.gsb|||||||BY-KanU-Transformation
30004|100020|32468|25832|9615|oberfranken.gsb|||||||BY-KanU-Transformation
For the time being, I've just symlinked the oberfranken.gsb to BETA2007.gsb.
The results I get seem to be ok.
Best regards!
 Thomas
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
