[Qgis-user] Image size in feature form not working
Carlos Dávila
cdavilam at orangecorreo.es
Sun May 20 08:51:20 PDT 2018
Hello
Since I switched to 3.0 I have a problem with images in feature form. I
have a field in my attribute table that contains the path to an image.
In Layer properties->Form->Fields I assign an "Attachment" widget to
that field. I have tried setting different widths/heights to that image
but when I open feature form image is always same size, an small
thumbnail of the same size than setting "Auto" for width and height.
QGIS doesn't takes into account the size set in layer properties. Is
this a known bug? I could not find anything related on bug tracker.
