[Qgis-user] QGIS 3 errors after install on macOS 10.13.4
Reg Maltais reginald.maltais at gmail.com
Wed May 23 15:19:34 PDT 2018
Here’s the truncated output to show just the postinstall lines:
May 23 18:14:15 Bellerophon installd[636]: PackageKit: Executing script "./postinstall" in /private/tmp/PKInstallSandbox.AXwBn9/Scripts/org.maptools.proj-framework-yosemite.xOVaFz
May 23 18:14:16 Bellerophon installd[636]: ./postinstall: Could not find an activated virtualenv (required).
May 23 18:14:16 Bellerophon installd[636]: PackageKit: Executing script "./postinstall" in /private/tmp/PKInstallSandbox.AXwBn9/Scripts/org.gdal.gdal22-framework-yosemite.ogoElJ
May 23 18:14:17 Bellerophon installd[636]: ./postinstall: Could not find an activated virtualenv (required).
May 23 18:14:17 Bellerophon installd[636]: PackageKit: Executing script "./postinstall" in /private/tmp/PKInstallSandbox.AXwBn9/Scripts/net.refractions.geos-framework-yosemite.Xrb86e
Interestingly, immediately below these are the PackageKit receipt writes:
May 23 18:14:17 Bellerophon installd[636]: PackageKit: Writing receipt for org.maptools.proj-framework-yosemite to /
May 23 18:14:17 Bellerophon installd[636]: PackageKit: Writing receipt for org.sqlite.sqlite3-framework-yosemite to /
May 23 18:14:17 Bellerophon installd[636]: PackageKit: Writing receipt for com.kyngchaos.UnixImageIO-framework-F-yosemite to /
May 23 18:14:17 Bellerophon installd[636]: PackageKit: Writing receipt for org.gdal.gdal22-framework-yosemite to /
May 23 18:14:17 Bellerophon installd[636]: PackageKit: Writing receipt for net.refractions.geos-framework-yosemite to /
So appears it thinks it worked.
> On May 23, 2018, at 5:22 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> That was just a test, only one python module.
> So, now it looks like pip is working in the Terminal, but not in my installers.  Try running the GDAL Complete installer again, but don't close it when it finishes.  Instead, open the Installer Log from the Window menu (in the installer).  Then use the popup menu to Show All Logs.  There should be some lines with "postinstall:", what do these say?
>> On May 23, 2018, at 4:59 AM, Reg Maltais <reginald.maltais at gmail.com <mailto:reginald.maltais at gmail.com>> wrote:
>> So that worked:
>> Processing /Library/Frameworks/GDAL.framework/Versions/2.2/Resources/GDAL-2.2.4-cp36-none-macosx_10_6_intel.whl
>> Installing collected packages: GDAL
>> Successfully installed GDAL-2.2.4
>> I’m getting different errors when opening QGIS now, I’m assuming due to not having run pip install for all of the various bits.
>> Couldn't load plugin 'processing'
>> ModuleNotFoundError: No module named 'psycopg2.extensions'
>> Traceback (most recent call last):
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 311, in loadPlugin
>>     __import__(packageName)
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in _import
>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 29, in
>>     from processing.tools.general import *              # NOQA
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/tools/general.py", line 39, in
>>     from processing.core.Processing import Processing
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 57, in
>>     from processing.algs.qgis.QgisAlgorithmProvider import QgisAlgorithmProvider  # NOQA
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/algs/qgis/QgisAlgorithmProvider.py", line 68, in
>>     from .FieldsCalculator import FieldsCalculator
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/algs/qgis/FieldsCalculator.py", line 45, in
>>     from .ui.FieldsCalculatorDialog import FieldsCalculatorDialog
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/algs/qgis/ui/FieldsCalculatorDialog.py", line 52, in
>>     from processing.gui.PostgisTableSelector import PostgisTableSelector
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/gui/PostgisTableSelector.py", line 34, in
>>     from processing.tools.postgis import GeoDB
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/tools/postgis.py", line 29, in
>>     import psycopg2.extensions  # For isolation levels
>> Python version: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 05:52:31) [GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.57)]
>> QGIS version: 3.0.2-Girona Girona, exported
>> Python Path:
>> /Users/goatsweater/Library/Application Support/QGIS/QGIS3/profiles/default/python
>> /Users/goatsweater/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins
>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
>> Couldn't load plugin 'MetaSearch' due to an error when calling its classFactory() method
>> ModuleNotFoundError: No module named 'owslib.csw'
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 336, in startPlugin
>>     plugins[packageName] = package.classFactory(iface)
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/__init__.py", line 29, in classFactory
>>     from MetaSearch.plugin import MetaSearchPlugin
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/plugin.py", line 34, in
>>     from MetaSearch.dialogs.maindialog import MetaSearchDialog
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/dialogs/maindialog.py", line 46, in
>>     from owslib.csw import CatalogueServiceWeb # spellok
>> Python Path:
>>> On May 22, 2018, at 9:31 PM, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180523/ac76b7d6/attachment.html>
