[Qgis-user] QGIS UTM projection of longitudes > 180 degrees
Eric Fielding
Eric.J.Fielding at jpl.nasa.gov
Sat May 26 12:25:02 PDT 2018
Nicolas,
Thanks for the suggestion. I am trying to use "save raster layer as" in
QGIS, but it is getting the extent of the data completely wrong in the UTM
zone 14 coordinates. It seems that QGIS (2.18.2 is what I have now) is
confused about the location of raster data at longitude > 180 degrees. I
will try to change the projection outside QGIS with "gdalwarp".
++Eric
Nicolas Cadieux wrote
> Hi,
> When experiencing this kind of difficulty, I normally just save the files
> in the desired projection. On the fly will have difficulties when
> crossing “projection limites”. Keep in mind that reprojecting data will
> change the values so keep a back up of the original data.
> Nicolas
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
