[Qgis-user] layers shift when exporting from composer to jpg
Martin Fisher martin.pescador at inventati.org
Wed May 30 03:37:01 PDT 2018
I do not know why you have encountered this problem, but perhaps you could try and alternative approach, depending on what you could like on the background. The obvious choice may be to use an ESRI map service from http://server.arcgisonline.com/arcgis/rest/services, as a WMS layer.
Best of luck
On May 28 2018, at 3:57 pm, MIKE MCGRADY <mikemcgrady at hotmail.com> wrote:
> I wanted to make a quick map using composer using a google hybrid map as background. Everything looked fine in the preview, but when I looked at the jpg, the data were no longer in the right space, having shifted some few km to the west. I am using QGIS 2.8.3 Wien. Am I missing something? Any work around?
> I am not very experienced with QGIS, so simple instructions work best (in all things)
> M. J. McGrady
> Am Rosenhugel 59
> A-3500 Krems
> Austria
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180530/8e06544b/attachment.html>
