[Qgis-user] Qgis - create attribute at regular interval along Z axis based on above attribute elevation
Francois Chartier
fra.chartier at gmail.com
Sat Nov 3 13:52:45 PDT 2018
in access you use 2 tables one with the range of a particular attribute and
the actual table you are working with, and you do a query.
the key is to not connect any attibute between tables when doing the
query, this way Access runs every possible permutation; its called a Cross
Join query/table.
then you have to export to excel or do it Access and only keep point that
are in between your data range ( example : ground surface and bottom of
borehole at that location).
i havent found another way of doing this but i am sure coding would work
too.
On Sat, Nov 3, 2018, 05:12 Nicolas Cadieux, <nicolas.cadieux at archeotec.ca>
wrote:
> Hi,
> I am not quite sure I understand what you are asking but in Excel you
> could use a “round up” function. Then perhaps use this rounded up number
> to do a vlookup on a table having the next higher up value? Not sure how to
> do that in Access.
> Not sure how or if you can do that in QGIS... I would need to see actual
> problem i think to be able to fully understand it.
> Nicolas
> > Le 2 nov. 2018 à 21:28, Francois Chartier <fra.chartier at gmail.com> a
> écrit :
> > Hi,
> > I am using Microsoft Access to populate a data set at regular intervals
> along the vertical axis between two elevation ranges (50 to 350 masl) and
> have the attribute (which does not exist) of that elevation to become the
> attribute of the above data point. example at 124.4, attribute at location
> 1 is A, therefore at 124 attribute becomes A, and this down to the next
> data point at example 121.6 masl where it is B (you will at location 1: at
> 124=A, 123=A, 122=A).
> > The goal being to interpolate different elevation slices at regular
> intervals as data points are not all at the same elevations depending on
> location.
> > I am able to do this with a Cross Join query in access and then removing
> any intervals above top and bottom. this is quite fastiduous, and i am
> wondering if i can do this straight in qgis, or
> > if i can run an interpolation with a condition that the value at
> location x,y equals the next above attribute value. this would keep the
> attribute table much smaller.
> > thanks
> > F
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181103/8ea227b1/attachment.html>
