[Qgis-user] Changing data source from Postgis to Geopackage
Alessandro Pasotti apasotti at gmail.com
Mon Nov 5 07:49:21 PST 2018
If you mean change data source functionality, this is now available in
https://github.com/qgis/QGIS/pull/8359
There is also a new "Change data source..." menu entry in the layer's
contextual menu, implemented for rasters and vectors.
On Mon, Nov 5, 2018 at 4:46 PM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> This seems a good candidate for an extra function of the browser. Probably
> a simple Py script or a plugin should do, at least as a prototype.
> Better add a ticket not to forget?
> All the best.
> Il 11/05/2018 03:17 PM, Andreas Neumann ha scritto:
> Hi,
> Ok - I am doing it in the text editor.
> I also had to change
> <provider encoding="System">postgres</provider>
> to
> <provider encoding="System">ogr</provider>
> After doing this change, it worked.
> Andreas
> On 2018-11-05 15:01, Alessandro Pasotti wrote:
> On Mon, Nov 5, 2018 at 2:54 PM Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> I have a relatively complex QGIS project with data storage in QGIS and
>> would like to change the data source of all layers to Geopackage.
>> I already have a Geopackage with the exact same data structure like in
>> Postgis (automatic export from Postgis through ogr2ogr).
>> Now I wonder what the best approach is to change all data sources from
>> Postgis to Geopackage?
>> Texteditor and search/replace or is there something more comfortable?
> Hi Andreas,
> you could first check if it works correctly with one layer, from the
> python console vl.changeDataSource('/my/new/path|layername=mylayername',
> 'layer_name', 'ogr')
> then exit without saving the project, make a backup and try search replace.
> Alessandro Pasotti
> w3:   www.itopen.it
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Paolo Cavallini - www.faunalia.euQGIS.ORG Chair:http://planet.qgis.org/planet/user/28/tag/qgis%20board/
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181105/6a331611/attachment.html>
